简介
Use this guide to replace the headphone jack and earpiece speaker assembly of your Samsung Galaxy Note.
你所需要的
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Insert your finger in the notch of the battery compartment.
Press the battery toward the rear facing camera while pulling outward.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly connector.
11等其他人完成本指南。
一条评论
I'd recommend getting an Original part if possible, the knock off speaker has no metal casing where the original does.
John Cobra - 回复
