跳转到主内容
Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement
你所需要的
  1. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, Stylus: 步骤 1 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, Stylus: 步骤 1 中的图像 2,2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, Rear Case: 步骤 2 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, Rear Case: 步骤 2 中的图像 2,2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 3 中的图像 2,2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, Battery: 步骤 4 中的图像 2,2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, MicroSD Card: 步骤 5 中的图像 1,3 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, MicroSD Card: 步骤 5 中的图像 2,3 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, MicroSD Card: 步骤 5 中的图像 3,3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, SIM Card: 步骤 7 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, SIM Card: 步骤 7 中的图像 2,2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 8 中的图像 2,2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, Midframe: 步骤 9 中的图像 1,1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 10 中的图像 2,2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 11 中的图像 3,3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 12 中的图像 1,3 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 12 中的图像 2,3 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 12 中的图像 3,3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 13 中的图像 2,2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, Upper Display Assembly Bracket: 步骤 14 中的图像 1,1
    • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
  15. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 15 中的图像 1,1
    • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
  16. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 16 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 16 中的图像 2,2
    • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
  17. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement, Headphone Jack/Earpiece Speaker Assembly: 步骤 17 中的图像 1,1
    • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly connector.
  18. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 18 中的图像 1,2 Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 18 中的图像 2,2
    • Use the point of a spudger to pry the headphone jack out of its recess in the display assembly.
  19. Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement: 步骤 19 中的图像 1,1
    • Use a pair of tweezers, or your fingers, to remove the headphone jack/earpiece speaker assembly from the display assembly.
结论
11等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,602 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,718篇指南
一条评论
I'd recommend getting an Original part if possible, the knock off speaker has no metal casing where the original does.
John Cobra - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 20,368
