跳转到主内容
Samsung Galaxy Note Edge Volume Button Replacement
你所需要的
  1. Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: 步骤 1 中的图像 1,2 Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: 步骤 1 中的图像 2,2
    • Place your device flat down on a clean surface.
    • Use a Spudger to remove the back cover using the notch at the top left.
  2. Samsung Galaxy Note Edge Volume Button Replacement: 步骤 2 中的图像 1,1
    • Use a Spudger to remove the battery using the notch located underneath the battery.
    • Note: During the creation of this guide, we did not have access to a battery.
  3. Samsung Galaxy Note Edge Volume Button Replacement: 步骤 3 中的图像 1,1
    • Remove the stylus from its sheathe.
  4. Samsung Galaxy Note Edge Volume Button Replacement: 步骤 4 中的图像 1,1
    • Use a Philips #000 Screwdriver to remove the fifteen 4mm screws.
  5. Samsung Galaxy Note Edge Volume Button Replacement: 步骤 5 中的图像 1,1
    • Use a Spudger to remove the black chassis and expose the motherboard.
  6. Samsung Galaxy Note Edge Volume Button Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Note Edge Volume Button Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Note Edge Volume Button Replacement: 步骤 6 中的图像 3,3
    • Use a Spudger to disconnect the following connections:
    • Connection 1
    • Connection 2
    • Connection 3
  7. Samsung Galaxy Note Edge Volume Button Replacement: 步骤 7 中的图像 1,1
    • Remove the connection for the front camera.
  8. Samsung Galaxy Note Edge Volume Button Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Note Edge Volume Button Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Note Edge Volume Button Replacement: 步骤 8 中的图像 3,3
    • Do not try to completely remove the motherboard until the final step.
    • Use a Spudger to gently lift the motherboard.
    • Remove the connection of the motherboard and the daughter board.
    • Remove the motherboard.
  9. Samsung Galaxy Note Edge Volume Button Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Note Edge Volume Button Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Note Edge Volume Button Replacement: 步骤 9 中的图像 3,3
    • Remove the volume button panel.
    • Remove the volume button connection.
    • Remove the volume button entirely.
结论
Lizzie Todd
于04/01/19注册
301 声望
创作了2篇指南
团队
IUPUI, Team S1-G1, Harley Spring 2019 IUPUI, Team S1-G1, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G1
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 518
