简介
Your Samsung Galaxy Note Edge boasts a 16 megapixel rear facing camera. If your camera does not take pictures on par with the quality it is capable of, you need to replace it. To access your rear facing camera, you will need to remove the back plate, mid-frame, and motherboard.
你所需要的
Power down your device and make sure that it is turned off.
Place the phone with the screen facing down on a clean flat surface.
Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
Remove the stylus from the stylus holder.
Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
Insert your spudger into the stylus socket and pry the midframe from the phone.
Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
The rear facing camera will be attached to the motherboard.
Using the pointed end of spudger, disconnect cable located to the right of the camera.
Remove the rear-facing camera from the device.
To reassemble your device, follow steps in reverse order.
