跳转到主内容
Samsung Galaxy Note Edge Front Camera Replacement
  1. Samsung Galaxy Note Edge Front Camera Replacement, Front Camera: 步骤 1 中的图像 1,3 Samsung Galaxy Note Edge Front Camera Replacement, Front Camera: 步骤 1 中的图像 2,3 Samsung Galaxy Note Edge Front Camera Replacement, Front Camera: 步骤 1 中的图像 3,3
    • Place your device face down on a clean surface.
    • Use a Spudger to remove the back cover using the notch at the top left.
  2. Samsung Galaxy Note Edge Front Camera Replacement: 步骤 2 中的图像 1,1
    • Use a Spudger to remove the battery using the notch located underneath the battery.
    • Note: During the creation of this guide, we did not have access to a battery.
  3. Samsung Galaxy Note Edge Front Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the stylus from its sheathe.
  4. Samsung Galaxy Note Edge Front Camera Replacement: 步骤 4 中的图像 1,1
    • Use a Philips #000 Screwdriver to remove the fifteen 4mm screws.
  5. Samsung Galaxy Note Edge Front Camera Replacement: 步骤 5 中的图像 1,1
    • Use a Spudger to remove the black chassis and expose the motherboard.
  6. Samsung Galaxy Note Edge Front Camera Replacement: 步骤 6 中的图像 1,1
    • Use a Spudger to separate the camera's connector.
    • Use a Spudger to remove the camera from its slot.
结论
Lizzie Todd
于04/01/19注册
301 声望
创作了2篇指南
团队
IUPUI, Team S1-G1, Harley Spring 2019 IUPUI, Team S1-G1, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G1
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 11
总计 330
