跳转到主内容
Samsung Galaxy Note Edge Display Assembly Replacement
你所需要的
视频概述
  1. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: 步骤 1 中的图像 3,3
    • Switch off the device.
    • Remove the back cover and the battery.
  2. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: 步骤 2 中的图像 1,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: 步骤 2 中的图像 2,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: 步骤 2 中的图像 3,3
    • Remove the Memory card, the SIM card and the S Pen.
    • Remove the screws by using Screwdriver Phillips #00
    • With a plastic opening tool emove the Back Frame.
  3. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: 步骤 3 中的图像 1,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: 步骤 3 中的图像 2,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: 步骤 3 中的图像 3,3
    • Disconnect one by one:
    • Coaxial antenna cable (x2)
    • Home Button flex cable
    • Display Flex cable
    • Stylus Sensor flex cable
    • Front Camera flex cable
  4. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: 步骤 4 中的图像 1,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: 步骤 4 中的图像 2,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: 步骤 4 中的图像 3,3
    • Pry up the connector on the back of the board to release the bottom part of motherboard.
    • Gently remove the logic board.
  5. Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: 步骤 5 中的图像 1,3 Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: 步骤 5 中的图像 2,3 Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: 步骤 5 中的图像 3,3
    • I prefer to test the new spare part before install it.
    • Transfer the Power button / Loud speaker flex cable.
    • Install the mother board.
    • Test the display.
    • To prevent damage to the put back the back frame before the test.
  6. Samsung Galaxy Note Edge Display Assembly Replacement, Check the Thermal Pads: 步骤 6 中的图像 1,1
    • Check the quality of the thermal pads (if the spare part is not original).
    • If its necessary use the thermal pads from the old assembly.
  7. Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: 步骤 7 中的图像 1,3 Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: 步骤 7 中的图像 2,3 Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: 步骤 7 中的图像 3,3
    • Insert wisdom here.
  8. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: 步骤 8 中的图像 1,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: 步骤 8 中的图像 2,3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: 步骤 8 中的图像 3,3
    • Remove the black Phillips screw,
    • the the charging port plate,
    • disconnect the Home buttons flex cable
    • and the coaxial antenna cable (x2).
    • Use hot air and a plastic opening tool to remove the Charging Port flex assembly.
  9. Samsung Galaxy Note Edge Display Assembly Replacement, Reassembling: 步骤 9 中的图像 1,1
    • To reassemble your device, follow these instructions in reverse order.
结论
2等其他人完成本指南。
ZFix
于12/09/13注册
195,919 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
329 名成员
创作了1,451篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 2,390
