简介
The power and volume buttons are responsible for turning your tablet on or changing the volume of your tablet. If the tablet doesn't respond to pressing any of those buttons, it is likely that the buttons are jammed or worn out from use. In order to resolve such issues, you'll have to replace the strip that holds the power and volume buttons. This guide shows you how to replace that strip.
你所需要的
The volume and power buttons are joined together on a common strip, so you are replacing both simultaneously.
25等其他人完成本指南。
7条评论
My wife's Samsung galaxy note 8 would not turn on. She has had it for three years and we thought it should be scrapped. I searched for this problem on line and found this site. Ordered new on off kit on e-bay. Followed these instructions. Very straight forward. Took less than 30 minutes. Reassembled and returned tablet to wife, who is very happy. Hoping for a good meal tonight! Thanks very much Joel. Martin
what is the part number or kit number of the on/off kit, how to order. please help.
My Samsung Galaxy Note 8.0 (wifi only) will not switch on or respond in any way to a known-good charger being plugged into it. It hasn't had much use since new, so I don't believe it's a worn out battery or switch, but I tested those anyway. It will not reset, or hard-reset, and I have removed and tested the function of the power tact-switch, that that works fine. The battery reads 4.2V. I fear that I've bricked it. Nothing I do gives any response. Is there anything else I can try?
Worked last night, was charged, checked charger(good), replaced charge port, replaced power/volume button, replaced battery. Not a peep out of the tablet. No battery image on screen. Tried hard reset etc. Nada. What now, trash can??? Can't see spending another 45 to 50 $$$ for mother board. Can any body prove Samsung built deliberate ob's into the tablet. Like read the software code.
louiseno36 - 回复
This is not a note 8 though
discoditto - 回复
