跳转到主内容
Samsung Galaxy Note 8.0 Headphone Jack Replacement
你所需要的
  1. Samsung Galaxy Note 8.0 Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
  4. Samsung Galaxy Note 8.0 Headphone Jack Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Galaxy Note 8.0 Headphone Jack Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
  5. Samsung Galaxy Note 8.0 Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Lift the top left corner of the battery up by the black tab.
  6. Samsung Galaxy Note 8.0 Headphone Jack Replacement: 步骤 6 中的图像 1,1
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
  7. Samsung Galaxy Note 8.0 Headphone Jack Replacement, Headphone Jack: 步骤 7 中的图像 1,2 Samsung Galaxy Note 8.0 Headphone Jack Replacement, Headphone Jack: 步骤 7 中的图像 2,2
    • Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver.
  8. Samsung Galaxy Note 8.0 Headphone Jack Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Note 8.0 Headphone Jack Replacement: 步骤 8 中的图像 2,2
    • Gently pry up the teal connector.
    • Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
  9. Samsung Galaxy Note 8.0 Headphone Jack Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Note 8.0 Headphone Jack Replacement: 步骤 9 中的图像 2,2
    • Gently pry up the gold connector.
  10. Samsung Galaxy Note 8.0 Headphone Jack Replacement: 步骤 10 中的图像 1,1
    • Remove the headphone jack from it's housing.
    • If difficult, use a plastic opening tool to pry up.
结论
6等其他人完成本指南。
Joel
于09/23/14注册
1,868 声望
创作了6篇指南
团队
USF Tampa, Team 12-2, Blackwell Fall 2014 USF Tampa, Team 12-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G2
4 名成员
创作了16篇指南
3条评论
Lightning struck while my son was on his tablet... no more headset audio? Replaced recommend parts still no audio. Plays fine without earbuds??? Insurance claim? What else could be the issue? Motherboard?
Shasta - 回复
what are these connectors on the left side of headphone jack which are connected to the backside plate?
sanco - 回复
this did not help getting the broken headphone jack out of my Samsung note 8
joshua- collins - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 6,836
