跳转到主内容
Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement
你所需要的
视频概述
Samsung Galaxy Note 4 Rear-facing Camera Lens Replacement
  1. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
    Back is not flexible and will shatter
    bobby moran - 回复
  2. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Facing Camera Lens: 步骤 2 中的图像 1,3 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Facing Camera Lens: 步骤 2 中的图像 2,3 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Facing Camera Lens: 步骤 2 中的图像 3,3
    • Use a pair of tweezers to pry off the rear-facing camera ring.
    • You may need to use the tweezers to run along the sides of the camera ring to loosen it.
  3. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: 步骤 3 中的图像 2,2
    • Use a pair of tweezers to peel off the camera ring adhesive.
  4. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: 步骤 4 中的图像 3,3
    • Gently slide one tip of a pair of tweezers underneath the rear-facing camera lens.
    • Pry upwards with the tweezers and remove the camera lens.
结论
16等其他人完成本指南。
Sophia
于03/25/14注册
43,810 声望
创作了62篇指南
2条评论
Iam gonna order this now. Thanks for the tip. How much should I expect to pay for new lens. ????
Tommy Holmes - 回复
aliexpress or ebay from china ~$1
altomic -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 35,556
