跳转到主内容
Samsung Galaxy Note 4 Front Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Note 4 Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy Note 4 Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy Note 4 Front Facing Camera Replacement, Battery: 步骤 2 中的图像 1,1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
  3. Samsung Galaxy Note 4 Front Facing Camera Replacement, SIM Card: 步骤 3 中的图像 1,2 Samsung Galaxy Note 4 Front Facing Camera Replacement, SIM Card: 步骤 3 中的图像 2,2
    • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
  4. Samsung Galaxy Note 4 Front Facing Camera Replacement, Midframe: 步骤 4 中的图像 1,1
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  5. Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 5 中的图像 3,3
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  6. Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  7. Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 7 中的图像 3,3
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  8. Samsung Galaxy Note 4 Front Facing Camera Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Remove the two 2.9 mm Phillips #00 screws.
  9. Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a set of tweezers to remove the two antenna cables.
  10. Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 10 中的图像 3,3
    • Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors.
  11. Samsung Galaxy Note 4 Front Facing Camera Replacement: 步骤 11 中的图像 1,1
    • Gently lift the motherboard out of the phone.
  12. Samsung Galaxy Note 4 Front Facing Camera Replacement, Front Facing Camera: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    • Turn the motherboard over.
    • Lift the metal tab up with the tweezers.
  13. Samsung Galaxy Note 4 Front Facing Camera Replacement, Unclip Plastic Clips: 步骤 13 中的图像 1,2 Samsung Galaxy Note 4 Front Facing Camera Replacement, Unclip Plastic Clips: 步骤 13 中的图像 2,2
    • Turn the motherboard back over.
    • Unclip the two plastic clips that connect the rear camera to the motherboard with your fingers.
结论
15等其他人完成本指南。
Derek Nola
于01/06/15注册
2,265 声望
创作了5篇指南
团队
Cal Poly, Team 70-6, Forte Winter 2015 Cal Poly, Team 70-6, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G6
4 名成员
创作了16篇指南
3指南评论
I change my LCD screen and camera stopped working. I bought new one and still no result. Please help !
ivaylo.lord - 回复
Have the same problem with the front camera. changed LCD und suddenly the front camera stopped working. bought 2 new ones and both the same. The IR-blaster sill works
Tuerkay - 回复
stopped front camera
Negatu Getahun - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 13,443
