跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 4 Antenna Replacement
你所需要的
    1. Samsung Galaxy Note 4 Antenna Replacement, Midframe: 步骤 1 中的图像 1,1
      • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      • Grasp the cap of the S Pen and remove it from its slot in the midframe.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note 4 Antenna Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Note 4 Antenna Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Note 4 Antenna Replacement: 步骤 2 中的图像 3,3
      • Insert a plastic opening tool between the midframe and the display assembly.
      • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
      • This adhesive is relatively weak, so no heat gun should be necessary.
      • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
      添加评论
    3. Samsung Galaxy Note 4 Antenna Replacement: 步骤 3 中的图像 1,1
      • Use a plastic opening tool to loosen the clasps around the battery housing.
      添加评论
    4. Samsung Galaxy Note 4 Antenna Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Note 4 Antenna Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Note 4 Antenna Replacement: 步骤 4 中的图像 3,3
      • Push on the battery housing to separate the midframe from the display assembly.
      • You will have to apply a reasonable amount of pressure to separate the two parts.
      • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
      添加评论
    1. Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: 步骤 5 中的图像 1,2 Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: 步骤 5 中的图像 2,2
      在这个步骤中使用的工具:
      • Pull up on the connectors with tweezers to detach them from the phone.
      • The blue dot on the shorter connector belongs nearest the bottom of the phone.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
21等其他人完成本指南。
Derek Nola
于01/06/15注册
2,295 声望
创作了5篇指南
团队
Cal Poly, Team 70-6, Forte Winter 2015 Cal Poly, Team 70-6, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G6
4 名成员
创作了72篇指南
6指南评论
hi where can i buy an antenna connector ?
i live in india.
ramumohan007 - 回复 分享
Google kar le
ravi raj - 回复 分享
I broke the actual ports that the antenna cables connect to on the mother board. Is thereally away to fix them or do I have to replace the whole logic/motherboard? I would like to keep my logic/motherboard because I don't want to lose all my text messages. What should I do?
shanonsmitt16 - 回复 分享
I also broke the connector component on the motherboard. It remains attached to the blue cable. Could this be re-soldered?
Leanahtan Eiddiwnid - 回复 分享
Is there a make shift way to put a extra antenna using one the two antenna ports above and to the left of the standard antenna cable. Without make any holes on the housing its self
Pedro A Sosa - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 45
总计 24,509
