跳转到主内容
Samsung Galaxy Note 3 Rear Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: 步骤 1 中的图像 1,1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: 步骤 2 中的图像 1,2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: 步骤 2 中的图像 2,2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - 回复
  3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: 步骤 3 中的图像 1,2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: 步骤 3 中的图像 2,2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: 步骤 4 中的图像 1,1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: 步骤 5 中的图像 1,1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: 步骤 6 中的图像 1,1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: 步骤 7 中的图像 1,2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: 步骤 7 中的图像 2,2
    • Remove the single screw beside headphone jack.
    You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
    Oriol Felisart - 回复
  8. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: 步骤 8 中的图像 1,2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: 步骤 8 中的图像 2,2
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: 步骤 9 中的图像 1,1
    • Pull up on the motherboard with tweezers.
    Can i change at&t board to 9002 or 9005??,
    Ayyaz - 回复
    My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
    soha Javed - 回复
    My wifi hotspot is not working
    Kiran Thopate - 回复
  10. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: 步骤 10 中的图像 1,1
    • Unclip the camera connecting cable using the plastic opening tool from the motherboard
    • Remove loose camera from base
结论
37等其他人完成本指南。
Brittany Gail
于09/23/14注册
8,504 声望
创作了8篇指南
团队
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G2
4 名成员
创作了25篇指南
3条评论
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - 回复
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - 回复
I shall be very thankfull for this act of kindness
Malik wajdan ali - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 13,433
