跳转到主内容
Samsung Galaxy Note 3 Motherboard Replacement
你所需要的
  1. Samsung Galaxy Note 3 Motherboard Replacement, Remove the rear case: 步骤 1 中的图像 1,1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: 步骤 2 中的图像 1,2 Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: 步骤 2 中的图像 2,2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Samsung Galaxy Note 3 Motherboard Replacement, Battery: 步骤 3 中的图像 1,2 Samsung Galaxy Note 3 Motherboard Replacement, Battery: 步骤 3 中的图像 2,2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Motherboard Replacement, S Pen: 步骤 4 中的图像 1,1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Motherboard Replacement, Unscrew Back Chassis: 步骤 5 中的图像 1,1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Motherboard Replacement, Remove Back Chassis: 步骤 6 中的图像 1,1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: 步骤 7 中的图像 1,2 Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: 步骤 7 中的图像 2,2
    • Remove the single screw beside headphone jack.
  8. Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: 步骤 8 中的图像 1,2 Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Motherboard Replacement, Motherboard Removal: 步骤 9 中的图像 1,1
    • Pull up on the motherboard with tweezers.
结论
74等其他人完成本指南。
Brittany Gail
于09/23/14注册
8,539 声望
创作了8篇指南
团队
USF Tampa, Team 2-2, Blackwell Fall 2014 USF Tampa, Team 2-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G2
4 名成员
创作了25篇指南
4指南评论
I'm looking for the screws for this phone, but all the search hits I've come across are for the screwdriver. Any leads on where I can find the screws?
Jared Lunt - 回复
I can replace motherboard sm-n9005 with motherboard sm-n900
yacine - 回复
I want to replace motherboard of galaxy note 3 SM-N900 with SM-N9005. Is it possible and can it convert 3g to 4G. Because my phone doesn't support 4G .it is 3g and I want to make it 4G .what should I do help me
Nippy Preet -
I am also looking for the same question
Jalil Ahmad -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 53
总计 51,524
