简介
How to do a Factory / Hard reset.
If your device keeps freezing,
If you've forgotten the Password, security PIN, pattern drill,
or it just doesn't work, take it back to factory settings.
!!! This procedure will erase all your personal data !!!
视频概述
Turn off the device completely
Press and hold the Volume Up, Home and Power keys at the same time.
When the logo "GALAXY Note 3" appears on the screen, release the Power key but continue to press and hold the Volume Up key and the Home key.
When the Android System Recovery menu appears, release the Volume Up and Home keys.
Use the Volume Up/Down keys for navigation in the menu and the Power key to select "'wipe data / factory reset".
In the next menu select "Yes -- erase all user data" and "reboot system now".
74等其他人完成本指南。
30条评论
My samsung galaxy note 3 phone. cant opend how can i find this.?
but os is crashed
How can I get in ? After factory reset my galaxy note 3 demands email and password set at first, meanwhile I have forgotten the password
Thank youuuuuu
Will this hard factory reset make my phone fadter and smoother
No not really.
Will my phone get faster with factory reset
Uh power it off then wait than turn it back on, it clears stuff up. Also clearing the cache does it to. Restart is kinda bad to do oof.
I factory reset my Samsung Galaxy Note 3 T-Mobile I put in my Metro PCS SIMs card it picked it up it worked for two days then it stopped working it reads the SIMS card but it won't let me go any further what could be wrong
I have a MetroPCS SIM card factory reset a Samsung Galaxy Note 3 put in my sims card and it worked work for 2 days then it stopped working what can be wrong won't pick up the internet it reads the card
How do I unlock my galaxy note 3 without factory reseting it? My kid was playing with my phone And put a back up pin on it and don't remember it…
i have samsung galaxy note 3
I am continuosly getting the messege as “ Unfortunately , the process android.process.media has stopped “
how to resolve the problem
How do I sync my phones data (when locked, forgot the pass/pin) to a different device? I just recently forgot my pass to my found, and wiping data. No. I have some games that can't be recovered. The device I am on now is a Samsung tablet E.
Would placing my sim card from my locked phone into this tablet I am currently on place all of my games and apps and what not onto here?
This helped me because my apps on the used phone that I got was outdated and wouldn’t update.
John Brown - 回复
It goes to recovery booting only. Doesn't give other options (Samsung Galaxy note 3 N-9005)
will this fix my flickering green screen problem ? cause it just went out on me while I was using it the other week , so I was thinking it mite be a O.S. update that didn't finish for some reason.
Madhavbiradar123@gmail.com
I wiped reset my Samsung galaxy note 3 and my selfie camera disappeared, kindly help on how to set it back
my phone is no enable bluetooth or wifi problem
after a hard reset of my note 3 and started setting up it almost done until the last part asking my samsung ID but i forget my user and password,,,what can i do to continue setting up my note 3???hoping you guys can help me fix this problem…thank you guys
Awesome Guys?!?
factory reset my samsung note 3 but frp locked
i factory reset my samsung note 3 because google frp locked. how you can remove frp from your computer
Reboot stop on software update an tap &go with NFC please help!!!
This does NOT work on all devices. I have done this on a Sam Gal Note 3. Removed memory and SIM, then after this “reset” the phone number and username (=email address) are STILL in system settings!! People all over the net are claiming this erases all user data. It does not.
frodo - 回复
Net gedaan en nix ik kom er niet meer in heel raar deze $@$* ik dacht het zou helpen.
elizabethdirksz.ed - 回复
After reboot got stuck on Eula & diagnostic data->software update->tap &go->and back again to EULA & diagnostic data
What should I do?
haris djauhari - 回复
