简介
本指南将说明如何进行恢复出厂设置
如果你的设备一直保持死机状态,
如果你忘记了你的密码、PIN码、解锁图案,
或者它仅仅只是无法正常运行,
你可以将它恢复至出厂设置。
!!! 这个步骤将会删除你所有的个人数据 !!!
视频概述
请完全关闭你的设备
同时按住“音量+”键、“Home”键和“电源”键
当屏幕出现GALAXY Note 3字样时,松开“电源”键,但依旧保持按住“音量+”键和“Home”键
当出现Recovery菜单时,松开“音量+”键和“Home”键
使用“音量+/-”键去上下移动光标到“wipe data / factory reset”(清除数据并恢复出厂设置)项后,按下“电源”键
在子菜单中选择“Yes -- erase all user data”(是的,删除所有用户的数据)和“reboot system now”(立刻重新启动系统)
74等其他人完成本指南。
由衷感谢以下译者:
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
30条评论
My samsung galaxy note 3 phone. cant opend how can i find this.?
but os is crashed
How can I get in ? After factory reset my galaxy note 3 demands email and password set at first, meanwhile I have forgotten the password
Thank youuuuuu
Will this hard factory reset make my phone fadter and smoother
No not really.
Will my phone get faster with factory reset
Uh power it off then wait than turn it back on, it clears stuff up. Also clearing the cache does it to. Restart is kinda bad to do oof.
I factory reset my Samsung Galaxy Note 3 T-Mobile I put in my Metro PCS SIMs card it picked it up it worked for two days then it stopped working it reads the SIMS card but it won't let me go any further what could be wrong
I have a MetroPCS SIM card factory reset a Samsung Galaxy Note 3 put in my sims card and it worked work for 2 days then it stopped working what can be wrong won't pick up the internet it reads the card
How do I unlock my galaxy note 3 without factory reseting it? My kid was playing with my phone And put a back up pin on it and don't remember it…
i have samsung galaxy note 3
I am continuosly getting the messege as “ Unfortunately , the process android.process.media has stopped “
how to resolve the problem
How do I sync my phones data (when locked, forgot the pass/pin) to a different device? I just recently forgot my pass to my found, and wiping data. No. I have some games that can't be recovered. The device I am on now is a Samsung tablet E.
Would placing my sim card from my locked phone into this tablet I am currently on place all of my games and apps and what not onto here?
This helped me because my apps on the used phone that I got was outdated and wouldn’t update.
John Brown - 回复
It goes to recovery booting only. Doesn't give other options (Samsung Galaxy note 3 N-9005)
will this fix my flickering green screen problem ? cause it just went out on me while I was using it the other week , so I was thinking it mite be a O.S. update that didn't finish for some reason.
Madhavbiradar123@gmail.com
I wiped reset my Samsung galaxy note 3 and my selfie camera disappeared, kindly help on how to set it back
my phone is no enable bluetooth or wifi problem
after a hard reset of my note 3 and started setting up it almost done until the last part asking my samsung ID but i forget my user and password,,,what can i do to continue setting up my note 3???hoping you guys can help me fix this problem…thank you guys
Awesome Guys?!?
factory reset my samsung note 3 but frp locked
i factory reset my samsung note 3 because google frp locked. how you can remove frp from your computer
Reboot stop on software update an tap &go with NFC please help!!!
This does NOT work on all devices. I have done this on a Sam Gal Note 3. Removed memory and SIM, then after this “reset” the phone number and username (=email address) are STILL in system settings!! People all over the net are claiming this erases all user data. It does not.
frodo - 回复
Net gedaan en nix ik kom er niet meer in heel raar deze $@$* ik dacht het zou helpen.
elizabethdirksz.ed - 回复
After reboot got stuck on Eula & diagnostic data->software update->tap &go->and back again to EULA & diagnostic data
What should I do?
haris djauhari - 回复
