跳转到主内容
Samsung Galaxy Note 10.1 Charging Port Replacement
你所需要的
  1. Samsung Galaxy Note 10.1 Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,3 Samsung Galaxy Note 10.1 Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,3 Samsung Galaxy Note 10.1 Charging Port Replacement, Charging Port: 步骤 1 中的图像 3,3
    • This is the back of the device and where you will begin to take it apart.
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use a metal spudger to pop up the corner of the silver piece.
    • Use the plastic opening tools to pry along the edges of the silver piece.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Charging Port Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Note 10.1 Charging Port Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Note 10.1 Charging Port Replacement: 步骤 2 中的图像 3,3
    • Remove the three 5mm screws indicated by the red circles with the Philips #00 Screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Charging Port Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Note 10.1 Charging Port Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Note 10.1 Charging Port Replacement: 步骤 3 中的图像 3,3
    • Remove the three 2 mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Pull the charging port indicated by the orange rectangle in picture two out from its position.
    • Unplug the black motherboard connector as indicated in the third picture.
    • Replace the charging port with a similar model.
结论
Gavin Tipker
于11/01/18注册
193 声望
创作了2篇指南
团队
IUPUI, Team S3-G1, Harley Fall 2018 IUPUI, Team S3-G1, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S3G1
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 3,120
