跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 10.1 Battery Replacement
你所需要的
    1. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: 步骤 1 中的图像 1,3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: 步骤 1 中的图像 2,3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: 步骤 1 中的图像 3,3
      • This is the back of the device and where you will begin to take it apart
      • It is neccesary to remove this piece first before removing the bigger back piece.
      • Use the plastic opening tools to pry along the indicated box.
      • Lift up the silver piece to reveal the rest of the back cover.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: 步骤 2 中的图像 1,3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: 步骤 2 中的图像 2,3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: 步骤 2 中的图像 3,3
      • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
      • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
      • Remove the back cover.
      • At this point use anti-static gloves or do NOT take it apart on carpet.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: 步骤 3 中的图像 1,3 Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: 步骤 3 中的图像 2,3 Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: 步骤 3 中的图像 3,3
      • Carefully remove all of the ribbons that connect over the battery.
      询问修复机器人
      添加评论
    4. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: 步骤 4 中的图像 1,3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: 步骤 4 中的图像 2,3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: 步骤 4 中的图像 3,3
      • Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
      • Disconnect the battery connector from the motherboard.
      • Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
      添加评论
结论
取消:我没有完成这个指南。
52等其他人完成本指南。
Tyler Salomone
于09/22/14注册
1,050 声望
创作了3篇指南
团队
USF Tampa, Team 3-7, Brown Fall 2014 USF Tampa, Team 3-7, Brown Fall 2014 的会员
USFT-BROWN-F14S3G7
3 名成员
创作了9篇指南
13指南评论
In Step 3, mention that you need to lift up on the black locks to take out the ribbons.
John Peterson - 回复 分享
Actually, on my device one lock was colored faun (beige). Lift them seen from the edge of the Note, not on the cable side.
dada64 - 回复 分享
Also, mention that you can disconnect the battery from the device by gently pulling out the battery and gently lifting up the wires.
This is not a plug to be pulled in the direction of the cables but vertically off the board. Putting it back in you simply plug the contacts down first, then the cable side of the plug.
dada64 - 回复 分享
When replacing the back cover, hook the bottom edge into the frame along the edge before trying to snap the rest in place along the sides.
charliesmallman55 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 106
总计 92,249
