跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement
你所需要的
  1. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: 步骤 1 中的图像 1,3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: 步骤 1 中的图像 2,3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: 步骤 1 中的图像 3,3
    • This is the back of the device and where you will begin to take it apart.
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use a metal spudger to pop up the corner of the silver piece.
    • Use the plastic opening tools to pry along the edges of the silver piece.
    • Lift up the silver piece to reveal the rest of the back cover.
    询问修复机器人
    添加评论
  2. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Remove the three 5mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
    询问修复机器人
    添加评论
  3. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: 步骤 3 中的图像 3,3
    • Remove the three 2 mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the orange box in the second picture.
    • Replace the 3.5 mm auxiliary port with a similar model.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Gavin Tipker
于11/01/18注册
208 声望
创作了2篇指南
团队
IUPUI, Team S3-G1, Harley Fall 2018 IUPUI, Team S3-G1, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S3G1
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 33
总计 1,468
