跳转到主内容
Samsung Galaxy Note 10.1 2014 Charging Port Replacement
你所需要的
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  1. Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Battery: 步骤 2 中的图像 1,1
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
  2. Samsung Galaxy Note 10.1 2014 Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,1
    • Using the PH000 screwdriver, remove the two black 3mm screws at the bottom of the device.
  3. Samsung Galaxy Note 10.1 2014 Charging Port Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Note 10.1 2014 Charging Port Replacement: 步骤 6 中的图像 2,2
    • After disconnecting the two blue electronic connectors, unhinge the metal part of the charging port with the black nylon spudger.
    • Make sure to also disconnect the other end of the ribbon as well by pushing back the thin black metal bar.
结论
14等其他人完成本指南。
Joseph Rasico
于02/20/17注册
2,160 声望
创作了6篇指南
团队
USF Tampa, Team S1-G6, Leahy Spring 2017 USF Tampa, Team S1-G6, Leahy Spring 2017 的会员
USFT-LEAHY-S17S1G6
3 名成员
创作了6篇指南
4条评论
Great guide. It helped me find the right component to order and gave me confidence to fix it myself. Actually the steps can be shortened. The battery does not need to be removed. So you need to do step 1 (remove the cover), first part of step 2 (remove the flat cable of the charge plug), step 5 and 6. Step 7 should be to replace the old part with the new part. And then of course the reversal of reconnecting via steps 6, 5, 2 and 1.
John Aap - 回复
Great guide. thanks.
at the SIM card slot corner, there is a little cylinder connected to the SIM card slot, what is it. i accidentally cut the ribbon between the SIM card slot and this piece.
Anas Sibaii - 回复
This guide enabled me to replace a bad charging port.
Note - the replacement microUSB port didn’t have the little chrome frame around the port - so I had to carefully scavenge the frame from the old one just to give the new port a little more support when plugging in a cable.
I’m going to use a magnetic charging adapter to reduce the wear and tear on the port, but this one saved the day.
Mister Muscles - 回复
Although I have changed this flat cable and also the relative micro USB connector and have installed the driver on the PC, the Tablet is not recognized, even if it charges the battery. I also tried to change micro USB cable and USB port on PC : - ((((
giovanni_gola - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 55
总计 12,093
