简介
Use this guide to replace the display on a Samsung Galaxy Nexus. Note that there may be slight differences between the phone depicted and your model of the Galaxy Nexus.
你所需要的
Open the back cover of the phone with your fingers or use the plastic opening tools to pry the back cover off of the phone.
Remove the battery by prying it free from the divot at the bottom.
Store the back cover and the battery in a safe place, such as a bowl, until you are ready to re-install them.
Flip the phone over so that the screen faces upward.
Insert a plastic opening tool into the seam between the screen and the outer case. Work the plastic opening tool around the phone without removing it from the seam.
Slowly pry the outer case from the screen.
It helps a lot to pry from the inside of the casing. After all the screws are out, the plastic is very loosely held together.
13等其他人完成本指南。
2条评论
with this guide , I found this repair easy to do. Thank you Tom G.
Deberían d3 poner los diagramas eléctricos para reparar gracias
