跳转到主内容
Samsung Galaxy Mega Speaker Assmebly Replacement
你所需要的
  1. Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Mega Speaker Assmebly Replacement, Battery: 步骤 1 中的图像 3,3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Speaker Assmebly Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Mega Speaker Assmebly Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Mega Speaker Assmebly Replacement: 步骤 2 中的图像 3,3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: 步骤 3 中的图像 1,3 Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: 步骤 3 中的图像 2,3 Samsung Galaxy Mega Speaker Assmebly Replacement, Speaker Assembly: 步骤 3 中的图像 3,3
    • Remove the 6 3.45 mm Phillips #000 screws from the bottom of the assembly surrounding the speaker.
    • Gently insert plastic opening tool through the inside groove of the speaker assembly.
    • Once the top part of the speaker assembly pops free. Gently lift up with your fingers to remove speaker.
结论
另外一个人完成了本指南。
nithin
于02/04/16注册
137 声望
撰写一个指南
团队
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 846
