跳转到主内容
Samsung Galaxy Mega Rear Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Mega Rear Facing Camera Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Mega Rear Facing Camera Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Mega Rear Facing Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Rear Facing Camera Replacement, Midframe: 步骤 3 中的图像 1,3 Samsung Galaxy Mega Rear Facing Camera Replacement, Midframe: 步骤 3 中的图像 2,3 Samsung Galaxy Mega Rear Facing Camera Replacement, Midframe: 步骤 3 中的图像 3,3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Rear Facing Camera Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the 2.55 mm Phillips #000 screw from the motherboard panel.
  6. Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 6 中的图像 3,3
    • Remove the connector clips on motherboard.
  7. Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Remove the final motherboard connectors.
  8. Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Mega Rear Facing Camera Replacement: 步骤 8 中的图像 3,3
    • Lift motherboard gently with finger.
    • There is a total of six connectors on the motherboard that need to be removed. All of them are shown in the pictures in this guide, make sure all of them are disconnected before removing.
  9. Samsung Galaxy Mega Rear Facing Camera Replacement, Rear Facing Camera: 步骤 9 中的图像 1,2 Samsung Galaxy Mega Rear Facing Camera Replacement, Rear Facing Camera: 步骤 9 中的图像 2,2
    • On the back of the motherboard, remove the connector of the rear facing camera from the motherboard.
    • Camera is now detached from device.
结论
另外一个人完成了本指南。
Max Rathman
于02/04/16注册
915 声望
创作了4篇指南
团队
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 646
