本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide instructs on how to replace a damaged back panel assembly. The back panel assembly provides the protection for all the internal components of the device. Most components of this device require the removal of the back panel to gain access to them.
你所需要的
Before starting, ensure device is completely turned off.
On the back of phone, locate the slot on the top left corner.
Insert plastic opening tool or fingernail and pull up on the back plate.
With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
Remove the 14 3.45 mm Phillips #000 screws from the assembly.
Gently, insert plastic opening tool into seam above the volume buttons of your phone.
5等其他人完成本指南。
