跳转到主内容
Samsung Galaxy Mega Midframe Replacement
你所需要的
  1. Samsung Galaxy Mega Midframe Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Mega Midframe Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Mega Midframe Replacement, Battery: 步骤 1 中的图像 3,3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Midframe Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Mega Midframe Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Mega Midframe Replacement: 步骤 2 中的图像 3,3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Midframe Replacement, Midframe: 步骤 3 中的图像 1,3 Samsung Galaxy Mega Midframe Replacement, Midframe: 步骤 3 中的图像 2,3 Samsung Galaxy Mega Midframe Replacement, Midframe: 步骤 3 中的图像 3,3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Midframe Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Mega Midframe Replacement: 步骤 4 中的图像 2,2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
结论
5等其他人完成本指南。
Aaron Fulton
于02/04/16注册
1,246 声望
创作了3篇指南
团队
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 1,075
