跳转到主内容
Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement
你所需要的
  1. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: 步骤 1 中的图像 3,3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 步骤 2 中的图像 3,3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: 步骤 3 中的图像 1,3 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: 步骤 3 中的图像 2,3 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: 步骤 3 中的图像 3,3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 步骤 4 中的图像 2,2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Earpiece Speaker/LED Indicator: 步骤 5 中的图像 1,1
    • Remove the black 2.55 mm Phillips #000 screw.
  6. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 步骤 6 中的图像 1,1
    • Remove the metal cover with the plastic opening tool.
  7. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 步骤 7 中的图像 2,2
    • Remove the motherboard clip from speaker assembly to the motherboard.
    • Gently lift the speaker and LED assembly out of the device.
    • Speaker assembly may be glued to the device, gently pry until it releases.
结论
4等其他人完成本指南。
Max Rathman
于02/04/16注册
915 声望
创作了4篇指南
团队
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,008
