跳转到主内容
Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement
你所需要的
  1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement, Screen & Digitizer Assembly: 步骤 1 中的图像 1,1
    • Before beginning, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 步骤 2 中的图像 2,2
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 步骤 3 中的图像 3,3
    • Use a phillips head PH000 and remove all 13, 1.4 mm visible screws.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use the pry tool to disconnect the digitizer
  4. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 步骤 4 中的图像 2,2
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
    • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
    • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
    • Once heated, gently pull the screen upward.
    • Make sure that the buttons are separating from the adhesive.
  5. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 步骤 5 中的图像 1,1
    • Now, seperate the screen from the outside frame of the phone (the bezel).
结论
3等其他人完成本指南。
一条评论
I want to repair my phone
Monirul Islam - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 1,273
