跳转到主内容
Samsung Galaxy Media Player 5 Earpiece Speaker Replacement
你所需要的
  1. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 1 中的图像 1,2 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 1 中的图像 2,2
    • Remove the SD Memory Card before working on the device.
    • Use a Phillips screwdriver to remove the 10 mm screw near the SD Memory Card port.
  2. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 2 中的图像 1,1
    • White caps cover screws on both sides of the charging port. Use the angled tweezers to remove them.
    • Use a blow dryer on low heat if necessary to loosen the adhesive.
  3. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips head screwdriver, unscrew the two 10 mm screws located on either side of the charging port.
  4. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 4 中的图像 3,3
    • Using the opening pick, pry at the bottom and work around each edge of the device until the front cover and back cover housing is separated.
    • You will hear a popping sound to indicate the separation.
  5. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, apply an upward force to detach the battery and the tab attached to it.
  6. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 步骤 6 中的图像 3,3
    • Using the plastic opening tool, apply an upward force to detach the speaker earpiece.
    • Use the tweezers to attach the new earpiece speaker in place of the original.
    • Use a blow dryer, on low heat settings, to loosen the adhesive on the speaker earpiece.
结论
2等其他人完成本指南。
China Ayala
于03/05/15注册
584 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 374
