简介
This guide shows yow to replace the display of your Samsung Galaxy M20 - SM-205FN.
你所需要的
Loosen the back cover
To do this, start at the headphone jack and lever between the back cover and the rest of the phone.
Keep going around the seam until the back cover is loose. Before fully taking off the back cover, carefully disconnect the fingerprint sensor's ribbon cable using a spudger or tweezers.
Now you should heat the entire front, either with a cherry stone pillow (wheat bag) or a heating plate, hair dryer, ironing on a low level is also possible if necessary.
Then use a plastic tool to pry the top of the camera. BE CAREFUL not to break the camera. Then go around and loosen the display. Reheat if necessary.
Pull the cable out of the slot at the bottom, clean the edges.
FINISHED!
Reverse the steps to reassemble your device. I am not responsible for any damage to your device.
5等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
