跳转到主内容
Samsung Galaxy Luna Motherboard Replacement
你所需要的
  1. Samsung Galaxy Luna Motherboard Replacement, SIM Card: 步骤 1 中的图像 1,1
    • Using a plastic opening tool, pry the divot to the left of the camera to take off the rear case.
  2. Samsung Galaxy Luna Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pull the corner nearest to the divot to remove the case from the phone.
  3. Samsung Galaxy Luna Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Luna Motherboard Replacement: 步骤 3 中的图像 2,2
    • Place your fingernail or a prying tool at the bottom of the battery and pry it out of the case.
  4. Samsung Galaxy Luna Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Luna Motherboard Replacement: 步骤 4 中的图像 2,2
    • By using your finger or a plastic opening tool, push the SIM card further into its container until a click is heard.
    • Once the click is heard grab the SIM card and slide it out of the container.
    • Remove the SIM card completely.
    • During reassembly, slide the new SIM card into the slot until a click is heard.
  5. Samsung Galaxy Luna Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Samsung Galaxy Luna Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Samsung Galaxy Luna Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Use a plastic opening tool, or your fingernail to to take off the rear case by prying the divot to the left of the camera.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Using an opening tool, take off the cover for the digitizer connector.
    • detach the connector with a tweezer or a plastic spudger.
  6. Samsung Galaxy Luna Motherboard Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Luna Motherboard Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Luna Motherboard Replacement: 步骤 6 中的图像 3,3
    • Place small suction cup on the center of screen and press firmly.
    • Hold the back of the phone and pull on the suction cup gently until the screen begins to bend.
  7. Samsung Galaxy Luna Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Luna Motherboard Replacement: 步骤 7 中的图像 2,2
    • Insert the small metal spudger into an opening on the phone and pry off the screen.
    • Avoid tearing any exposed circuits as the screen is being removed.
    • Make sure the screen is completely detached from the motherboard before removing it.
  8. Samsung Galaxy Luna Motherboard Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Luna Motherboard Replacement: 步骤 8 中的图像 2,2
    • Using a Philips PH000 screwdriver, remove the nine 3 mm screws.
  9. Samsung Galaxy Luna Motherboard Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Luna Motherboard Replacement: 步骤 9 中的图像 2,2
    • Using a metal spudger, gently pry the button frame off the motherboard.
    • Do the same for the motherboard.
    • Avoid scraping the circuitry on the motherboard, as they can be very fragile.
  10. Samsung Galaxy Luna Motherboard Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy Luna Motherboard Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy Luna Motherboard Replacement: 步骤 10 中的图像 3,3
    • Using a Philips PH000 screwdriver, remove the black screw.
    • Use the metal spudger to pry open the motherboard cover.
    • Be careful when prying the cover of the motherboard. avoid scratching the motherboard circuitry.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S6-G1, Eyestone Spring 2018 USF Tampa, Team S6-G1, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S6G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 692
