跳转到主内容
Samsung Galaxy Luna LCD display Replacement
你所需要的
  1. Samsung Galaxy Luna LCD display Replacement, LCD display: 步骤 1 中的图像 1,1
    • Attach a small suction cup to the lower half of the glass screen.
  2. Samsung Galaxy Luna LCD display Replacement: 步骤 2 中的图像 1,1
    • Apply pressure to the middle section of the screen while pulling up the lower edge by pivoting your wrist.
  3. Samsung Galaxy Luna LCD display Replacement: 步骤 3 中的图像 1,1
    • Once you've opened a large enough gap, insert a Spudger tool between the glass and the motherboard.
    • Slide the Spudger tool around the gap until the screen is completely separated from the motherboard.
    • The LCD is very fragile,be careful when sliding the spudger around the gap.
  4. Samsung Galaxy Luna LCD display Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Luna LCD display Replacement: 步骤 4 中的图像 2,2
    • Pull the rear panel up and away to completely separate it.
    • make sure the panel is completely detached from the phone frame before separating it.
  5. Samsung Galaxy Luna LCD display Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Luna LCD display Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Luna LCD display Replacement: 步骤 5 中的图像 3,3
    • Place the spudger tool between the LCD and the glass screen.
    • Slide the spudger tool in between the screen and the display until both are completely separated from each other.
    • The LCD is very fragile, do not apply excessive force when prying the glass panel
结论
2等其他人完成本指南。
xingyu chen
于02/14/18注册
266 声望
撰写一个指南
团队
USF Tampa, Team S6-G1, Eyestone Spring 2018 USF Tampa, Team S6-G1, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S6G1
4 名成员
创作了5篇指南
2条评论
Hola, cual es el numero de parte de la pantalla a reemplazar?
Luis A. Andueza - 回复
It appears that OEM screens are no longer available for this phone. I was able to find this third party display assembly that looks like it would work, but I can’t attest to its functionality, so there would be a bit of risk involved for you. Hope that helps!
Austin Blakely -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 1,001
