跳转到主内容
Samsung Galaxy Light USB Charging Port Replacement
你所需要的
  1. Samsung Galaxy Light USB Charging Port Replacement, Remove back cover: 步骤 1 中的图像 1,1
    • Remove the back cover with the opening tool to reveal the battery
  2. Samsung Galaxy Light USB Charging Port Replacement, Remove battery: 步骤 2 中的图像 1,1
    • Now remove the battery and keep it somewhere safe for now
  3. Samsung Galaxy Light USB Charging Port Replacement, Unscrew motherboard from plastic protection: 步骤 3 中的图像 1,1
    • Unscrew the nine screws shown with the Philips #0 screwdriver
    • Be sure not to lose any screws
  4. Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: 步骤 4 中的图像 1,3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: 步骤 4 中的图像 2,3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: 步骤 4 中的图像 3,3
    • You must detach and replace the entire motherboard the replace the charging port
    • Slowly lift the motherboard up to pull it off the orange strip
    • Pull slowly, you do not want to break this strip
  5. Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: 步骤 5 中的图像 1,2 Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: 步骤 5 中的图像 2,2
    • Due to the connector being sawdered on you must replace the whole mother boar so, insert your new motherboard
    • Make sure you line it up correctly with the orange strip
结论
3等其他人完成本指南。
Diandra
于10/16/14注册
210 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G2
3 名成员
创作了5篇指南
3条评论
sawdered = soldered...Other than that it is pretty straight forward...thank you...
Jeffrey Harp - 回复
Typo, Step 4:
“You must detach and replace the entire motherboard the replace the charging port”
the = to
(could have been ‘to’ or ‘then’, but last step dictates it means ‘to replace the port’’
Thanks for the excellent and simple guides!
Kim Lindstrom - 回复
why dont you just replace the charging port??? any good tech should have that skill in the bank 100%
Philip Moskal - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,094
