跳转到主内容
Samsung Galaxy Light Motherboard Replacement
你所需要的
  1. Samsung Galaxy Light Motherboard Replacement, Remove Back Cover: 步骤 1 中的图像 1,1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Motherboard Replacement, Remove Battery: 步骤 2 中的图像 1,1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Motherboard Replacement, Unscrew Midframe: 步骤 3 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Motherboard Replacement, Remove Midframe: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: 步骤 5 中的图像 1,3 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: 步骤 5 中的图像 2,3 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: 步骤 5 中的图像 3,3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
结论
7等其他人完成本指南。
Diandra
于10/16/14注册
210 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,145
