跳转到主内容
Samsung Galaxy Light Earpiece Speaker Replacement
你所需要的
  1. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Back Cover: 步骤 1 中的图像 1,1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Battery: 步骤 2 中的图像 1,1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Earpiece Speaker Replacement, Unscrew Midframe: 步骤 3 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Midframe: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: 步骤 5 中的图像 1,3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: 步骤 5 中的图像 2,3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: 步骤 5 中的图像 3,3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: 步骤 6 中的图像 1,2 Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to pry up the headphone jack, vibrator, and earpiece speaker assembly.
结论
4等其他人完成本指南。
Paul Goyette
于10/21/14注册
475 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 676
