跳转到主内容
Samsung Galaxy J7 v Volume Button Replacement
你所需要的
  1. Samsung Galaxy J7 v Volume Button Replacement, Screen: 步骤 1 中的图像 1,1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 v Volume Button Replacement: 步骤 2 中的图像 1,1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 v Volume Button Replacement: 步骤 3 中的图像 1,1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 v Volume Button Replacement, Home button: 步骤 4 中的图像 1,1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 v Volume Button Replacement: 步骤 5 中的图像 1,1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 v Volume Button Replacement, Volume Button: 步骤 6 中的图像 1,2 Samsung Galaxy J7 v Volume Button Replacement, Volume Button: 步骤 6 中的图像 2,2
    • Remove the screws around the home button and the screws above.
  7. Samsung Galaxy J7 v Volume Button Replacement: 步骤 7 中的图像 1,1
    • Pull the screen away from the panel.
  8. Samsung Galaxy J7 v Volume Button Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy J7 v Volume Button Replacement: 步骤 8 中的图像 2,2
    • Remove all adjacent screws.
  9. Samsung Galaxy J7 v Volume Button Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy J7 v Volume Button Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy J7 v Volume Button Replacement: 步骤 9 中的图像 3,3
    • Pop off panel from plastic hold.
  10. Samsung Galaxy J7 v Volume Button Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy J7 v Volume Button Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy J7 v Volume Button Replacement: 步骤 10 中的图像 3,3
    • Use the pointed end of the spudger to push down the button hold, then the volume button can be removed by pushing it down.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 14
过去 30 天: 49
总计 952
