简介
This guide is a step by step instruction on how to replace the rear camera in your Samsung Galaxy J7 V smartphone. Before you begin make sure you have all the tools necessary and set aside the recommended amount of time to complete the repair.
你所需要的
Insert a Jimmy tool under one of the corners of the display and gently raise the display.
Locate the socket of the home button.
Fit the metal spudger in between the socket and the home button.
Use the indent on the right side of the phone to lift up the backing
With the phone faced downwards, remove the backing of the case, lifting up from the right side
Carefully remove the battery by lifting the bottom side, and then fully remove the battery
2等其他人完成本指南。
