跳转到主内容
Samsung Galaxy J7 V Power Button Replacement
你所需要的
  1. Samsung Galaxy J7 V Power Button Replacement, Screen: 步骤 1 中的图像 1,1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 V Power Button Replacement: 步骤 2 中的图像 1,1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 V Power Button Replacement: 步骤 3 中的图像 1,1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 V Power Button Replacement, Home button: 步骤 4 中的图像 1,1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 V Power Button Replacement: 步骤 5 中的图像 1,1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 V Power Button Replacement, Volume Button: 步骤 6 中的图像 1,2 Samsung Galaxy J7 V Power Button Replacement, Volume Button: 步骤 6 中的图像 2,2
    • Remove the screws around the home button and the screws above.
  7. Samsung Galaxy J7 V Power Button Replacement: 步骤 7 中的图像 1,1
    • Pull the screen away from the panel.
  8. Samsung Galaxy J7 V Power Button Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy J7 V Power Button Replacement: 步骤 8 中的图像 2,2
    • Remove all adjacent screws.
  9. Samsung Galaxy J7 V Power Button Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy J7 V Power Button Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy J7 V Power Button Replacement: 步骤 9 中的图像 3,3
    • Pop off panel from plastic hold.
  10. Samsung Galaxy J7 V Power Button Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy J7 V Power Button Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy J7 V Power Button Replacement: 步骤 10 中的图像 3,3
    • Use the pointed end of the spudger to push down the button hold, then the volume button can be removed by pushing it down.
  11. Samsung Galaxy J7 V Power Button Replacement, Power Button: 步骤 11 中的图像 1,2 Samsung Galaxy J7 V Power Button Replacement, Power Button: 步骤 11 中的图像 2,2
    • Use the metal spudger tool to lift the metal bar holding the button in place.
  12. Samsung Galaxy J7 V Power Button Replacement: 步骤 12 中的图像 1,1
    • Use the metal spudger tool to push on the power button to remove it from the phone.
结论
To reassemble your device, follow these instructions in reverse order. Please don't miss a screw!
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 104
总计 3,294
