跳转到主内容
Samsung Galaxy J7 V Motherboard Replacement
你所需要的
  1. Samsung Galaxy J7 V Motherboard Replacement, Screen: 步骤 1 中的图像 1,1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 V Motherboard Replacement: 步骤 2 中的图像 1,1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 V Motherboard Replacement: 步骤 3 中的图像 1,1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 V Motherboard Replacement, Home button: 步骤 4 中的图像 1,1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 V Motherboard Replacement: 步骤 5 中的图像 1,1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 V Motherboard Replacement, Remove the backing: 步骤 6 中的图像 1,2 Samsung Galaxy J7 V Motherboard Replacement, Remove the backing: 步骤 6 中的图像 2,2
    • Use the indent on the right side of the phone to lift up the backing
    • With the phone faced downwards, remove the backing of the case, lifting up from the right side
  7. Samsung Galaxy J7 V Motherboard Replacement, Remove the battery: 步骤 7 中的图像 1,1
    • Carefully remove the battery by lifting the bottom side, and then fully remove the battery
  8. Samsung Galaxy J7 V Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Remove fourteen screws from the midframe using a Phillips #00 screwdriver.
  9. Samsung Galaxy J7 V Motherboard Replacement: 步骤 9 中的图像 1,1
    • Flip the phone to the back side where the battery was removed.
    • Apply pressure with your hands to pop the midframe off.
  10. Samsung Galaxy J7 V Motherboard Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy J7 V Motherboard Replacement: 步骤 10 中的图像 2,2
    • Flip the phone back over.
    • Remove the single black screw from the motherboard using a Phillips #00 screwdriver.
    • Place a few iFixit opening picks beneath the motherboard.
    • Spread the opening picks evenly around the motherboard to ensure it does not bend as you remove it.
    • Lift the motherboard using the iFixit opening picks.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 67
总计 1,148
