跳转到主内容
Samsung Galaxy J3V Headphone Jack Replacement
你所需要的
  1. Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,3 Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 2,3 Samsung Galaxy J3V Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 3,3
    • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
  2. Samsung Galaxy J3V Headphone Jack Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy J3V Headphone Jack Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy J3V Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
  3. Samsung Galaxy J3V Headphone Jack Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy J3V Headphone Jack Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy J3V Headphone Jack Replacement: 步骤 3 中的图像 3,3
    • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
    • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
  4. Samsung Galaxy J3V Headphone Jack Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy J3V Headphone Jack Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy J3V Headphone Jack Replacement: 步骤 4 中的图像 3,3
    • Remove connector tab with spudger then carefully remove headphone jack with tweezers.
结论
Carry Corrales
于09/28/17注册
738 声望
创作了5篇指南
团队
USF Tampa, Team S3-G3, Nance Fall 2017 USF Tampa, Team S3-G3, Nance Fall 2017 的会员
USFT-NANCE-F17S3G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 561
