跳转到主内容
Samsung Galaxy J3 Prime Battery and SIM Card Replacement
  1. Samsung Galaxy J3 Prime Battery and SIM Card Replacement, Battery and SIM card: 步骤 1 中的图像 1,1
    • Power off your phone by holding down the power button; located on the top right-hand side of your phone for approximately 5 seconds.
    • Make sure to remove your phone charger if it is plugged in.
  2. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 2 中的图像 3,3
    • Turn your phone so the back is facing up.
    • Using your fingers or a spudger, remove the cover by lifting it from the slot located on the top right-hand side underneath the volume buttons.
  3. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 3 中的图像 2,2
    • Remove the battery by lifting it up from the slot in the bottom right corner.
  4. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 4 中的图像 3,3
    • Slide the SIM card down from the SIM card slot.
    • Make sure to firmly press down on the SIM card when sliding down, for easy removal.
  5. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 5 中的图像 2,2
    • Slide the new SIM card into the slot.
    • When you slide the new SIM card in, make sure to place the golden pleated side face down.
    • Now place the new battery into the battery slot by aligning it correctly with the four gold contacts.
  6. Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy J3 Prime Battery and SIM Card Replacement: 步骤 6 中的图像 3,3
    • Put the cover back by sliding it on, and firmly pressing it shut.
    • Power on your phone.
结论
Aisha Bashir
于07/01/21注册
133 声望
撰写一个指南
团队
一条评论
I need to replace the sim card slot on one of these is it individual or does it come out with the whole motherbord and what parts do I need to order?
Mitchell Hedlund - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 747
