跳转到主内容
Samsung Galaxy J3 Mission Screen Replacement
你所需要的
  1. Samsung Galaxy J3 Mission Screen Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
  2. Samsung Galaxy J3 Mission Screen Replacement, Battery: 步骤 2 中的图像 1,1
    • Make sure that your device is powered off before removing the battery.
    • Insert your fingernail into the battery removal slot and pull back until the battery pops out.
  3. Samsung Galaxy J3 Mission Screen Replacement, Screen: 步骤 3 中的图像 1,1
    • Use an iFixit opening tool to lift the screen from one of the vertical sides of the phone and continue gently prying until the screen is loose enough to safely remove.
    • The damaged screen is connected under the screen assembly with a small plastic brace; remove this with an iFixit opening tool.
    • Be careful around the home button. It has little tabs to keep it in the frame, but they will break if the adhesive isn’t loosened with age or heat.
结论
To install a new screen try the connector before adding any adhesive, then put it back together by following these steps in reverse order.
6等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 17
总计 1,930
