跳转到主内容
Samsung Galaxy J3 Luna Pro Headphone jack Replacement
你所需要的
  1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Motherboard Change: 步骤 1 中的图像 1,1
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 2 中的图像 3,3
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 3 中的图像 3,3
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 4 中的图像 3,3
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: 步骤 5 中的图像 3,3
    • Remove the motherboard from the mid-frame.
  6. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: 步骤 6 中的图像 1,2 Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard.
结论
另外一个人完成了本指南。
Brandon Mendoza
于01/29/18注册
673 声望
创作了2篇指南
团队
USF Tampa, Team S5-G5, Passmore Spring 2018 USF Tampa, Team S5-G5, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S5G5
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 1,217
