跳转到主内容
Samsung Galaxy J3 Home Key Replacement
你所需要的
  1. Samsung Galaxy J3 Home Key Replacement, Home Key: 步骤 1 中的图像 1,1
    • Separate the back casing from the phone by carefully using your fingers to pry them apart.
  2. Samsung Galaxy J3 Home Key Replacement: 步骤 2 中的图像 1,1
    • Remove the battery.
  3. Samsung Galaxy J3 Home Key Replacement: 步骤 3 中的图像 1,1
    • Remove all ten screws by using a Phillips #000 screwdriver.
  4. Samsung Galaxy J3 Home Key Replacement: 步骤 4 中的图像 1,1
    • Use the flat side of a spudger to remove the middle frame bezel.
    • Do not twist or wrench the spudger during this step as it will cause the screen to crack.
  5. Samsung Galaxy J3 Home Key Replacement: 步骤 5 中的图像 1,1
    • Gently pull the glass up from the side of the phone and push the home button out.
    • When you pull the glass up, it will make a popping sound. This is normal.
  6. Samsung Galaxy J3 Home Key Replacement: 步骤 6 中的图像 1,1
    • Replace the home button and press the glass back in place.
结论
3等其他人完成本指南。
2条评论
NEVER NEVER do this!!!! In the last picture I can see the LCD broken apart!!! You may never open an J3 like this, because the LCD screen will brake and this is what happen in the last 2 pictures, this man separated the screen in 2 parts and now the screen does not work. Check some videos in youtube and you will know what I am saying.
Leonardo Sierra - 回复
you see, you clearly know nothing about phones, because the last picture shows nothing resembling a broken lcd. however, there is a much simpler way of doing this and he did take an over-complicated approach. sidenote: if you use youtube for your information instead of guides by professionals, you have some issues.
Blins Cat -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 2,728
