跳转到主内容
Samsung Galaxy J3 Emerge Screen Replacement
你所需要的
  1. Samsung Galaxy J3 Emerge Screen Replacement, Screen: 步骤 1 中的图像 1,3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: 步骤 1 中的图像 2,3 Samsung Galaxy J3 Emerge Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Heat up the edges of the screen with a hair dryer.
    • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
    • Work the iFixit Opening Tools around the whole screen to break the glue.
  2. Samsung Galaxy J3 Emerge Screen Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy J3 Emerge Screen Replacement: 步骤 2 中的图像 2,2
    • Lift the screen up from the bottom.
    • The screen could crack when lifting it up.
    • Pry the gray cover open.
  3. Samsung Galaxy J3 Emerge Screen Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy J3 Emerge Screen Replacement: 步骤 3 中的图像 2,2
    • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
结论
6等其他人完成本指南。
PJ Yebisu
于01/24/19注册
256 声望
撰写一个指南
团队
Cal Poly, Team S19-G2, White Winter 2019 Cal Poly, Team S19-G2, White Winter 2019 的会员
CPSU-WHITE-W19S19G2
4 名成员
创作了5篇指南
2条评论
I was using my J3 Emerge last night and all of a sudden the screen just went blank. At first, I could press the power button and I would see the Samsung logo for a split second but now it doesn’t do that. You can tell it is trying to turn on because you can see it change from black to a blue like color. I thought it might be the battery so I took it to a store today to buy a new one but he said that wasn’t the problem. It is charging but I just can’t see anything. Do you think I need a new LCD screen or is it something else? Thank you!
theleachs - 回复
Gostei da aula parabens muito gratificante.
athoscost - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 17
总计 2,999
