跳转到主内容
Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement
你所需要的
  1. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Screen: 步骤 1 中的图像 1,3 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Screen: 步骤 1 中的图像 2,3 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Screen: 步骤 1 中的图像 3,3
    • Heat up the edges of the screen with a hair dryer.
    • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
    • Work the iFixit Opening Tools around the whole screen to break the glue.
  2. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 2 中的图像 2,2
    • Lift the screen up from the bottom.
    • The screen could crack when lifting it up.
    • Pry the gray cover open.
  3. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 3 中的图像 2,2
    • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
  4. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Motherboard: 步骤 4 中的图像 1,2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove the eleven Phillips #00 3.5mm screws.
    • If the screws get stuck when removing, try using tape to get them out. Place the adhesive side of tape on the screws and pull the tape off the spot.
  5. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 5 中的图像 1,1
    • Turn the phone over and push down where the battery was.
    • There will be a loud clicking noise when applying pressure.
  6. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 6 中的图像 1,1
    • Insert the iFixit Opening Pick between the motherboard and the panel.
    • Work the iFixit Opening Pick around the outside of the motherboard.
  7. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 7 中的图像 2,2
    • Pry the motherboard away from the phone using your hand.
  8. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement, Home Button and Audio Jack: 步骤 8 中的图像 1,1
    • Slide the home button to the left to pop it off.
  9. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 9 中的图像 1,1
    • Remove the connector where the home button was using the iFixit Opening Pick.
  10. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 10 中的图像 1,1
    • Lift up the connector and push it through the motherboard by following the ribbon.
  11. Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy J3 Emerge Home Button and Audio Jack Replacement: 步骤 11 中的图像 2,2
    • Follow the ribbon and gently pop the audio port out using the iFixit Opening Pick.
结论
2等其他人完成本指南。
Hugh Cosculluela
于01/24/19注册
507 声望
创作了4篇指南
团队
Cal Poly, Team S19-G2, White Winter 2019 Cal Poly, Team S19-G2, White Winter 2019 的会员
CPSU-WHITE-W19S19G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,487
