此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
转到步骤 1 ↓这是适用于 Samsung Galaxy J3 Emerge(型号 SM-J327P)的屏幕更换指南。请使用吹风机加热固定屏幕的显示屏粘合剂。如果屏幕无响应或设备无法开机,可能需要更换屏幕。如果原装屏幕发生屏幕破裂,也可以对其进行更换。
你所需要的
工具
要重新组装设备,请按相反顺序执行这些说明。
7等其他人完成本指南。
2指南评论
I was using my J3 Emerge last night and all of a sudden the screen just went blank. At first, I could press the power button and I would see the Samsung logo for a split second but now it doesn’t do that. You can tell it is trying to turn on because you can see it change from black to a blue like color. I thought it might be the battery so I took it to a store today to buy a new one but he said that wasn’t the problem. It is charging but I just can’t see anything. Do you think I need a new LCD screen or is it something else? Thank you!
