跳转到主内容
Samsung Galaxy J1 Volume Button Replacement
你所需要的
  1. Samsung Galaxy J1 Volume Button Replacement, Midframe: 步骤 1 中的图像 1,1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Volume Button Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy J1 Volume Button Replacement: 步骤 2 中的图像 2,2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Volume Button Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Volume Button Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy J1 Volume Button Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy J1 Volume Button Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Volume Button Replacement, Volume Button: 步骤 5 中的图像 1,2 Samsung Galaxy J1 Volume Button Replacement, Volume Button: 步骤 5 中的图像 2,2
    • Use the flat edge of a spudger to push the volume button out.
    • Remove the volume button.
结论
5等其他人完成本指南。
Sean Kramer
于02/14/18注册
1,467 声望
创作了6篇指南
团队
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 22
总计 1,832
