跳转到主内容
Samsung Galaxy J1 Motherboard Replacement
你所需要的
  1. Samsung Galaxy J1 Motherboard Replacement, Midframe: 步骤 1 中的图像 1,1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy J1 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Motherboard Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy J1 Motherboard Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy J1 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Samsung Galaxy J1 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Use the flat edge of a spudger to disconnect the ear speaker connector.
  6. Samsung Galaxy J1 Motherboard Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy J1 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger disconnect the digitizer connector.
  7. Samsung Galaxy J1 Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy J1 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger disconnect the front-facing camera cable connector.
  8. Samsung Galaxy J1 Motherboard Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy J1 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the front-facing camera.
  9. Samsung Galaxy J1 Motherboard Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy J1 Motherboard Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy J1 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Use the flat end of a spudger to gently pry under the motherboard.
    • Remove the motherboard.
  10. Samsung Galaxy J1 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Use the flat end of a spudger to disconnect the rear camera cable connector.
  11. Samsung Galaxy J1 Motherboard Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy J1 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove the rear camera.
结论
22等其他人完成本指南。
Sean Kramer
于02/14/18注册
1,452 声望
创作了6篇指南
团队
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G4
3 名成员
创作了6篇指南
4条评论
can you plz give use a amazon link to part
Sean Gynn - 回复
Very good illustration..where can I get a motherboard?
Isaac Samuels - 回复
Where can I get a motherboard for this phone Samsung J100?
Isaac Samuels - 回复
I need the details of the motherboard
FUN FIRST - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 34
总计 6,624
