跳转到主内容
Samsung Galaxy J1 Midframe Replacement
你所需要的
  1. Samsung Galaxy J1 Midframe Replacement, Midframe: 步骤 1 中的图像 1,1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Midframe Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy J1 Midframe Replacement: 步骤 2 中的图像 2,2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Midframe Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Midframe Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy J1 Midframe Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy J1 Midframe Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
结论
6等其他人完成本指南。
Sean Kramer
于02/14/18注册
1,506 声望
创作了6篇指南
团队
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 2,167
