跳转到主内容
Samsung Galaxy J1 Glass Screen Replacement
你所需要的
  1. Samsung Galaxy J1 Glass Screen Replacement, Midframe: 步骤 1 中的图像 1,1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Glass Screen Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy J1 Glass Screen Replacement: 步骤 2 中的图像 2,2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Glass Screen Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Glass Screen Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy J1 Glass Screen Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy J1 Glass Screen Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Glass Screen Replacement, Glass Screen: 步骤 5 中的图像 1,2 Samsung Galaxy J1 Glass Screen Replacement, Glass Screen: 步骤 5 中的图像 2,2
    • Using the flat end of a spudger, disconnect the digitizer cable connector.
  6. Samsung Galaxy J1 Glass Screen Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy J1 Glass Screen Replacement: 步骤 6 中的图像 2,2
    • Using a plastic opening tool pry between silver digitizer and black back piece.
    • Slowly slide plastic opening tool around the screen to loosen the adhesive.
    • Be careful not to tear the digitizer cable when threading it through the plastic housing.
  7. Samsung Galaxy J1 Glass Screen Replacement: 步骤 7 中的图像 1,1
    • Carefully separate display assembly from the plastic housing.
结论
19等其他人完成本指南。
Sean Kramer
于02/14/18注册
1,452 声望
创作了6篇指南
团队
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G4
3 名成员
创作了6篇指南
2条评论
In my Samsung J110h, Some of the right side keys in keyboard not working. They are P, Zero, In message screen, the sending button etc..
I am in desperate need for advice to rectify.
Will somebody help me.
My mail Id”: karupusolai@gmail.com
Solaimalai - 回复
I was having the display issue. So I bought Samsung Galaxy J1 Screen replacement. And, I replaced it by myself using the information in this.
harshithaemazel - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 37
总计 4,693
