跳转到主内容
Samsung Galaxy Grand Prime Micro USB Port Replacement
你所需要的
  1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: 步骤 2 中的图像 1,3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: 步骤 2 中的图像 2,3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: 步骤 2 中的图像 3,3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: 步骤 3 中的图像 1,3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: 步骤 3 中的图像 2,3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: 步骤 3 中的图像 3,3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 4 中的图像 2,2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 5 中的图像 2,2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: 步骤 6 中的图像 1,2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: 步骤 6 中的图像 2,2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: 步骤 7 中的图像 1,2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 8 中的图像 2,2
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: 步骤 9 中的图像 1,2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 10 中的图像 3,3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Grand Prime Micro USB Port Replacement: 步骤 11 中的图像 2,2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
  12. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: 步骤 12 中的图像 1,3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: 步骤 12 中的图像 2,3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: 步骤 12 中的图像 3,3
    • Using a soldering iron to solder off the charging port.
    • Be careful soldering iron gets extremely hot.
结论
33等其他人完成本指南。
Kyle Ruff
于02/04/16注册
6,725 声望
创作了5篇指南
团队
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 40
总计 34,759
